3 phase education
RRRDAD
Lincoln Neb.
I need an air compressor for my sand blaster. I'm looking at a three phase compressor. Without getting real specific how big of breaker is required? Currently I have a 40 amp for my welder.
mm08822
without getting real specific, you can only get a multitude of guesses as to what your answer could be.
Some basic q's to narrow down the possibilities:
do you have 3 phase power available?
Voltage
HP of expected ac motor
Inrush of motor during startup
larry_g
oregon
I need an air compressor for my sand blaster. I'm looking at a three phase compressor. Without getting real specific how big of breaker is required?.
Your motor size will dictate the breaker size, and the wire size, you need. In addition to the breaker you will need a motor starter, and a disconnect.
Bigger question is, Do you have 3 phase in your shop?
lg
no neat sig line
Steve from Socal
Hutchinson Ks.
Without getting specific three phase motors use 1.73 amps per amp of single phase power. If the three phase motor is listed at 17 amps, it will need 29.41 amps not including losses in the conversion.
Steve
Norcal
If 3Ø is not available, then it opens a expensive can of worms, compressors do not do well with phase conversion equipment. Single phase motors are commonly available up to 10 HP, but be prepared to spend dough buy them.
marinusdees
Edgewood, Washington
It's not the size of the breaker. It's the price of three cans on the pole and the 3 phase service entrance. As noted, air compressors do not fare well with phase converters. Too much startup current is required.
Unfortunately as others have said youre gonna have to get into the messy details.
Do u even have 3-phase service? I would assume so since youre asking about a 3 phase compressor.
If u do, the next detail is HP and voltage rating on compressor.
Voltage
Inrush current doesnt need to be known and isnt a listed factor on nameplates. code allows breakers to be sized max 250% of NEC FLC current for this reason.
R
RRRDAD
Lincoln Neb.
Ok thank you. I did buy the thre phase compressor. My shop does have three phase so $200 for electrician and we should be blasting away.
well wait a minute.
What type of 3 phase service do u have? Theres different types each with different voltages.
What is the voltage and HP rating on the compressor?
Im confused why youre asking any of this if u planned on using an electrician in the first place.
What was the point?
EOC_Jason
Bentonville, AR
Maybe he was thinking he could just plug it into the welder's receptacle (assuming it was 3 phase too)... Though I'm guessing he bought at least a 5HP compressor and has realized it's going to need to be hard-wired.
Rock knocker
Steve
That doesn't make a whole lotta sense
Bert_
NW Iowa
I think he's saying if no 3Ø is available, any type of converter will require approximately 1.73A of input power on 1Ø to run a 3Ø motor.
In this case it doesn't apply because the OP has 3Ø. Just look at the motor nameplate and size the breaker up to 250% of FLA
mm08822
[/b]
Excuse my missing carriage return on that last point. You are correct inrush value not needed for design/install. I know n/p only lists FLA's. My point was after the basics are out of the way, the ocp allowance for inrush on a motor ckt lets in another variable to answer his q.
Just b/c code says 2.5x max - doesn't mean you have to go to that value. If you have other breakers onhand under 2.5x, you may to to use them before buying another at ~2.5x.
Real point was, this q w/o specific info was like asking how much a car costs with no other detail.
mm08822
OP, So any info sources on the micro inverters failing everywhere?
Yes thats why i said MAX
Hes ignoring u. :lol_hitti
This isn't for you, find something that plugs in to a common circuit.
Huh? The OP has 3 phase...
And If the compressor is 3HP+ it cant plug into any circuit unless expensive pin and sleeve plugs are used.
larry_g
oregon
This thread is gives good reason to why I am reluctant to engage members with under 100 posts.
lg
no neat sig line
