Ramper
What is the difference between using a 1-pole dimmer and a 3-way dimmer for a light? If I use a 1-pole will it be that I will have to always turn off the light with the same switch I turned it on with?
Lutron makes a nice setup that allows you to dim from any location. I have a dimmer at the doorway and one on either side of the bed. It's not cheap, it was over $100 for the 2 3 way switches and the 4 way.You use the 3 way dimmer if you have 3 way switches. Note that you can only have one 3 way dimmer switch the other mush be a standard 3 way switch.
