3 way switch not working as such
Jsf721
LI, NY
I am not keen on playing with electricity. All I ever do is replace an outlet or switch when I can turn breaker off and swap like for like.
In this case I had an electrician in to install a new high hat so I asked him to install a new lighted 3 way switch at the top and bottom of the staircase. When he came I showed him the area to install the high hat (really an LED wafer light these days) and place I wanted the switch. He came and installed it while I was a t work and my wife checked it worked but not as a 3 way. So I called the Sparky and he said he must have not installed the traveler wire and would come to fix. He was supposed to come yesterday and no show and no return text. So is this an easy fix or not? I hate having to walk down stairs to shut the light off.
Buckaroo5
Central Ohio
Unless he simply did not hook it up, likely not easy - you have to pull the wire through the wall between the switches. Difficult to believe anybody who knew what they were doing could "forget" to install the traveler wires.
MovingAlong
You had a working configuration and didn't want to tackle the direct replacement. Now you don't have a working system and want to troubleshoot/fix a licensed electricians mistake?
For you - I'm going to say this may not be an easy fix.
I recommend the Black & Decker Complete Home Wiring book, but this one at Home Depot should cover your situation.
paulsomlo
Northern Colorado
Hopefully, he means "must have not hooked up" rather than "must have not installed". Either way, he should have tested it before he left.
Here's a quick check: If you remove each switch cover plate, you will probably see a cable containing 3 wires (red,black,white) and a cable containing 2 wires (black,white). Each switch should have 3 terminals and each terminal should have a wire attached.
I don't have a good feeling about this - was there attic space up above to run cables?
J
Jsf721
LI, NY
There was a functioning 3 way switch in place prior to him messing with it. Now that 3 way functionality is not workings. Sparky said i must have not connected (I said installed) the traveler. Its there unless he cut it.
LOW1
ontario
It really should be an easy fix. Are there a red, black and a white wire to each switch? Check the connections for each. If one is loose attach it to the terminal that does not have a wire to it BUT NOT to the green ground terminal.
75gmck25
Alexandria, VA
Your initial description is a little confusing. Did he just replace an existing 3 way switch with a new lighted switch, or did he add a new 3 way switch and new wiring to the system?
3 way switches need a 14/3 or 12/3 cable (with red/black/white wires) to operate. There are variations in the wiring scheme and the switch locations, but you always need 3 wires at the switch. If the original installation did not have 3 wires, you have to run new wire to both switches.
nadogail
Coronado, CA
Until it is fixed don't give him a good review, if he dosen't fix it at no charge, note that you have problems with him and his work in your review.
J
Jsf721
LI, NY
If there’s an existing three-way then all he messed up on was the travelers
The owner is coming. And said all along it was the travelers that were missed. Just took too long to come back and walking down stairs to shut off lights these few weeks sucked.
J
Jsf721
LI, NY
So as promised here is the resolve. The switches now work. The travelers were reconnected. Sparky was here for like 15 min or less to correct. It was
a no charge call. Took too long to return but he said he’s very busy on a large job far from my home
