I'm in the process of wiring my new detached garage. I will have a centrally located fan/light, but for the remainder of the lighting I will be relying on linkable 4' LED lights powered by 6 separate outlets in the ceiling (3 on each side of the garage).
The plan was to run 12/2 from the breaker to the first 3-way switch at the east door, 12/3 to the second 3-way switch at the north door, and 12/2 to the first of the 6 outlets. The first outlet would be GFCI to provide "downstream" GFCI protection as required (operating under the 2017 NEC in MN).
My question is - will the use of 3-way switches cause a power imbalance which will trip the GFCI?
Alternatively, if anyone has a better idea I'm all ears
