30,000 btu Hot Dawg Vertical Venting
nmarolf
First time poster, long time lurker.
I'm installing a Hot Dawg unit heater in my garage. Will be venting vertically through a finished (drywall and insulation) ceiling and then through the roof. The heater has a 3" exhaust and I casually thought that I would just go buy a venting kit. But online research is proving difficult (if not infuriating). The only kits I can find are 4". I'm assuming I should just go with a 4" kit and add a 3"-4" adapter out the back of the unit...?
Or I locate individual pieces of 3" B-Vent....? Also, i'm having trouble finding a kit with a collar for going through the drywall/insulation. Oh, and I haven't found a kit with a drip T that I assume is necessary. All of them just have a 90 degree elbow.
Any pointers or suggestions would be incredibly helpful at this point. Thanks in advance.
PoorUB
Fargo, ND
Is the heater rated for vertical venting?
Yes, you can vent vertically, but I forget if B-vent is acceptable.
Nmarlof. What do the instructions say?
I would not worry about a "kit" , just buy what you need. Most home stores have B-vent. Stainless is a but tougher to buy locally.
N
nmarolf
Yes the instruction manual indicates vertical venting, double wall being recommended.
Thanks for the replies.
N
nmarolf
Alright, my local big box store had 3" B Vent in stock with all the parts I needed except for a tee with cleanout cap. Didn't know they had 3" but it makes sense now that I found it. I can't find info on what my local code requires but the Modine installation clearly indicates a tee drip leg/clean out so I ordered one online.
PoorUB
Fargo, ND
Make sure it is the same brand. B-vent does not exchange between brands.
If you ordered it from the same big box store, then never mind!
