30 Gallon Husky Compressor
NJ Diver
I was curious to see if anyone had any ingenious pluming ideas/set up for the drain on these type compressors.
The drain is really close to the ground and a bit of a PITA to get to.
KenB
Pittsburgh, PA
I mounted 1 in. larger wheels, then used a drain extender like HD's sku #1000053233. I mounted the valve end to one of the leg struts and added an elbow so it would shoot down into my drain pan.
Ken
George in Rancho Cordova
The red HF compressor has the drain hole located off-center. One must tilt the compressor to drain the tank. Unless the tank is "parked" at an angle, an auto drain would be ineffective.
N
NJ Diver
Thanks guys. I may have to go with Ken's idea as the bottom of the tank is pretty close to the ground so I was concerned that there would be a clearance issue with just an elbow and piping out the side.
