30 oz. Caulk gun assistance
cyberdyke
Washington
Howdy, I'm building a sound proof booth and using some caulk that comes only in a 30 oz. size. I'm having a very hard time getting the caulk out of the dispenser, because of the size of the dispenser, the thickness of the caulk and hand strength. I was hoping someone might have a suggestion as to how I might make this job easier? Thanks!
C
cyberdyke
Washington
Yes, but I'd really like to stay on budget $50 is all I'm willing to spend. I don't suppose Home Depot or Lowes rents those?
tarbellb
Oregon
Using sausages correct?
Only thing you can really do for easier appliaction force is cut a bigger tip or buy a powered gun.
There are better and worse guns, some advertise higher squeeze (drive) strength.... I would shop around
If you are a Prime member here is a smoking deal on a Albion gun warehouse deal- $35
Amazon warehouse new and used section
C
cyberdyke
Washington
Not sure what a 'sausage' is, but expect you're talking about a tube of caulk?
yes I can cut the nozzle bigger but then the opening in the tube can only be so big, right?
Fresh yes its with in its used by date.
I'm experienced with using the small 10 0z. sized gun. Some times the cheap handles cut into my hands but don't have any issues getting the caulk out of the gun. But this jumbo sized one is really difficult to use. :(
PugetDude
Superstition Mountains, AZ
Heat gun to warm the tube, cut the opening bigger, make sure you obliterated the foil seal.
I’ve never found them any more difficult to use than the smaller tubes.
tarbellb
Oregon
Not necessarily. Some product comes in quart tubes, like regular caulk on steroids.
You are right, I forgot about the 29oz hard cartridge types
Heat could be good, tub of hot water for tubes in queue
Otherwise largest hole possible and a better (drive ratio) gun are about your only good options
mike93lx
Richmond, VA
A high thrust ratio gun. I have two quart guns, a regular and a high ratio. The high ratio is easy to dispense, it's just a lot of squeezing.
JES 1 Qt. 26:1 High-Thrust Caulk Gun
SKU# 305860776
C
cyberdyke
Washington
sausage is a larger caulking package than the large caulking tube. I thought that's what you were using . it looks like a large sausage casing, thus the sausage term.
Mmm I'm using a 30oz. tube of caulk in a gun that fits that size.
I decided to make sure the opening in the tube to the nozzle was as large as possible, I also cut off more of the nozzle. It is now easier to use the gun. However, I think I'm using more caulk, but I guess its a trade off.
Thank everyone for your help!
danski0224
Near Naperville, IL
What kind of caulk gun are you using? It makes a difference.
You shouldn't have to cut an extra big part off of the nozzle. Yes, more than a little hole in the foil seal is needed.
The only real exception is cold temperatures, but a good caulking gun will easily blow out the cardboard tube if the stuff won't come out of the nozzle.
So called "professional" caulking guns not made in China can easily be 50 bucks or so and not readily available in a box hardware store. None of the good manual ones will have a toothed dispensing rod.
Box store knockoffs of good caulking guns are more readily available. They usually aren't as good as a nice caulking gun, but certainly better than the $3 version.
C
cyberdyke
Washington
it was $20 from home depot or lowes. I had to pad the handle, and as I said I ended up cutting 3/8" extra off after varying the opening into the nozzle was completely open.
tarbellb
Oregon
That cheap gun is your problem
Those stamped metal guns are prone to flexing and making your hand hurt. Better guns have cast parts, and better mech to push and importantly hold position.
Ive sworn off those stamped guns
Half-fast eddie
Virginia
That's a **** caulking gun.
Don’t be so negative and condescending. Say it like this: mr cyberdyke, that caulking gun is designed as a price-point mass-market tool intended to be sold to consumers who place bargain prices before quality tools that exhibit proper performance. Many contractors would consider that model to be a consumable item, purchased to be used for the duration of the project and then discarded with the empty tube.
mike93lx
Richmond, VA
Agreed. Grabbing a high thrust cast gun will make this a non issue
Sumboodie
AK
Meh, I'd rather go with the less wordy response.
If the baby is ugly, it's ugly.
C
cyberdyke
Washington
Agreed not the best tool, but this is probablly the only time I'm going to need this size of caulk gun. I was trying to do this on a budget, which I've exceeded by 50%. :(. I've got it working better now that I've expanded the opening between the tube and the nozzle. Thanks everyone!! :)
