Finally decided to go with the Legacy Industrial Nohr -S mainly for the ease of use, because I would mainly be by myself. The saw cuts where filled with sand and then the gel crack filler. The floor was ground with a HD diamabrush unit done with water to keep the dust down. Then the floor was pressure washed and let dry for 5 days with floor heat set for 70 degrees.
