30x30 or 30x40
Georgia Gator
Still in the planning stages. I already know one is bigger than the other but
Just looking to see if that 10ft is really worth the extra 2-2500. Thanks for your
Help I really enjoy the site.
James-W
Southeastern Wisconsin
Welcome to the forum.
I would say the bigger the better, make is as large as your budget allows and the zoning allows. Trust me on this, you can always use more room and to do it now will be MUCH cheaper than adding on to the building at some point later on.
joe_padavano
Northern VA
If you are even asking this question, you apparently don't need the extra space.
The difference between 30 ft and 40 ft means the difference between fitting two cars end-to-end or not.
Farrier
California Foothills
Why not get a 40x30 instead?
Two things you'll never hear:
(1) A woman that wishes it was smaller
(2) A man that wishes it was smaller
Build as large as you can. Even if you have to save up for a few extra months. Don't be like me or others on here....... Building twice
73RR
Blank Email
Central Ory-Gun
I have a 30x30 garage to park two of my wife's car's in...just two...Not much room around them if I was trying to actually work on them.
Tonellin
Boston
I have a 30x30 as well and parking three cars is tight especially if you plan on working on any of them or having any type of sizable equipment or toolboxes. If you can get an extra 300sq ft for a couple grand it's a no brainer
polizei1
Cinci, OH
My garage will be 32x24, because that's as much as I can get. You should absolutely build the larger size!
texasranger
Maryland
Coming at this from a different angle, what are your constraints as far as lot coverage? I have an acre but can't build on more than 15% including sidewalks, driveways, etc. Impervious ground cover. Will you need to add on to your house in the future? Add a pool?
I'd build the extra 10' in a heart beat if you can afford it and the other constraints don't apply...
Dr Stan
Owensboro, KY
:+1: on 30 X 40. I screwed up and built mine with 8' walls. This spring it will be raised to 12'. Raising the roof a PITA for sure.
OutlawDrifter
KS
Go with the bigger building. I went 36x40x14 to maximize my budget, wish I could have done a 40x60, but not enough dinero! I've worked out of a 24x30 for years, 10' in either direction would have been a huge benefit.
Voi
Western South Dakota
Even at 2500 that extra 300 square feet is just a bit over $8 per square foot. I think that's worth it.
If this is a stick build consider a multiple of 4' for both your gable and eave. A friend of mine just built a 30 x 40 house and is kicking himself for not going 32x40.
Concrete and truss package would have been not much more and there would have been less waste for both his roof and wall sheathing. It would have been cheap square footage.
If it's a post frame build then you need to account for pole spacing for your area and the width of the steel panels. Multiples of both 3' and 8' tend to be safe choices.
I only mention this if both space and budget are concerns, which I assume they are.
rburke65
Canfield, Ohio
As said....it's not an extra 10'....it's an extra 300 sq. ft.! And a 32' X 40' is a better multiple. And reguardless if it's stick or pole, PLEASE concidered a 10' side wall .....at least. The comments here are all "experience talking". It might cost ya a few dollars more, but in the long run, it will save you many dollars.
87GN
phila, pa
Garage size is like **** and like money. Some is good, more is better, too much is just right.
RegeSullivan
Canonsburg Pennsylvania (South of Pittsburgh)
I think the real questions is, is it worth the extra money for another 300 sqft. Well... absolutely... it's worth it. 30 x 30 is a good sized garage for 2 cars. 30 x 40 is a building you can also park a couple of cars in. The only way I'd go 30 X 30 is if I couldn't afford to go 30 X 40 or I had a building and just needed a garage for a couple of cars... but all that said, what the hell do I know.
jp828108
I have a 30 by 40 and like most already have it filled. Needs cleaned up and organized to create more space in it. Go 30 by 40 if you can. I have 10 foot ceilings, and would love to have 16 or 18. It would look a little weird, but would allow a mezzanine to be put in on part, and a lift on the other portion.
G
Georgia Gator
Thanks for all the input. It will be stick built, 6x6's wrapped in metal.
1 roll up door and 2 man doors and 2 windows. No cars parked in there
Just tractor welder and tools.
The Tool Tyrant
Bonita, Ca. (San Diego)
Well GG, seems to be a trend here. This is probably one of the few questions that you could ask here and get a unanimous reply to. It's a no brainer, built it as big as you can afford and are allowed to. :thumbup:
srr
San Diego
I have a 24x30 and when I bought the house 12 years ago had the money,time, space to add 30' to the back of the garage. Wish I had. There is no such thing as too big when it comes to a garage/work shop.
Shadowdog500
Down the shore
It will be too small no matter how big you build it.
Build it as big as you can possibly afford or get away with with zoning. You will thank yourself later.
Chris
Paladin306
Oklahoma City, OK
You're not serious are you?...If ANYONE on this forum votes 30'X30', they should immediately be banned :banhim:
Make it smaller?...that's just crazy talk :bitchslap
I totally agree with Tool Fool. 1200 square feet is going to be so much better than 900. I'd also make sure the walls were at least 12'.
Just my 2cents,
