30'x40' garage lighting recommandation???
przemekmsu
South Jersey
Hello,
I am finishing up a 30'x40' garage. What type??? How many??? Lights should I install???? Thanks in advance for your help.
Familyof8kids
Smyrna, TN
Hello,
Have you looked at many other recent discussions for the same thing?
Is the area in rough wiring stage or is the drywall up and finished? Are switches set and circuits ran to locations? Do you have a work bench area? What is the use of the area?
Trying to help just need more data.
cyamaha2007
St.Charles MO
Id go with the home depot 8ft t-8 flush mount fixture. They are pretty nice for 40 bucks. I put 35 8ft fixtures in my 2000sqft shop its 14ft tall tho. It made for a really bright assembly area. If all you need is a place to park cars thats way more fixtures than you need.
Ray916MN
Orono, MN
To answer this question, you need to answer some questions, like the height of the garage. It would also help to know:
- interior finish/color
- what you plan on doing in the garage
Ceiling height drives fixture type (hi or low bay - bare fixtures or fixtures with reflectors)
Color and finish of the interior provides an idea of how much light will reflect in the space versus being absorbed.
Tasks drive how much light you want. The finer the task, the more light you need. http://www.engineeringtoolbox.com/light-level-rooms-d_708.html
Answer these questions and then you can use a lighting calculator like the one here http://www.gelighting.com/LightingW...sistant-toolkit/lighting-layout-estimator.jsp to figure out how many lights of a given type/specification you'll need to light your space to the desired level. Adjustments to the number of lights you need, depend on the interior color and how much reflectivity you want to attribute to the ceiling or fixture reflectors. In general, the lower the ceiling and the whiter the interior color the less you need to adjust the output of the lighting calculator for ceiling or absorption loss.
You'll also want to give some consideration to the temperature (color) of the lighting. Warmer lighting (yellower) has a color temperature below 5000 K. Day light color is generally 5000-6500K. The higher the color temperature the harsher the lighting.
Other factors to consider would be cost to buy, cost to operate, cost to maintain, cold temperature performance.
Personally, I went with a 100 lumen target for my all white interior 24x48x15 garage with an assumption of no reflected light from the all the white ceiling using bare fixtures, and went with eighty eight 4 foot 6500K T8 bulbs. Since the ceiling does reflect some light, I probably end up with more like 150 lumens. To ensure no dark spots, I arranged the lights in four 44 foot long rows of 2 bulb bare fixtures. I chose this layout to minimize the number of bulbs that get blocked when the garage doors are opened. As you might suspect, the type of fixtures you elect to use need to be factored into how you want to lay out your lighting.
Of course, you can also back off on the amount of lighting you install in a garage if you intend to use work lamps instead of fixed lighting to light for specific tasks.
KPSquared
Wetaskiwin, Alberta, Canada
There was a great link to understanding lighting here a little while ago.
I have 30x36 with 12'6" ceilings. I'll be running 28 four foot T8 fixutres with no reflectors on a white ceiling. From what I can tell, it will be awesome and bright. There's some of my layout in my build thread I think.
P
przemekmsu
South Jersey
The ceiling hight is 10'. No sheet rock or celling installed yet. Just finished framing it.
i want to use it as a shop. Rebuild an old classic one day. I want to make sure I have enough light. Finish inside is going to be light color.
Familyof8kids
Smyrna, TN
How many doors/windows and qty per side such as:
North - 1 garage door 8x12
South - 1 entry door 3x8
East - 2 windows - 36x48
