my wife and i just bought an acreage with no garage so i finally get to build my dream garage. i have a couple hotrods, sled and quad so there is lots of wrenching taking place.
just to keep things short i will start with the pad and later i will add the rest of the build, i haven't totally made up my mind but i think i might go with what i think is called a slab on grade. is what i mean is i will not have a pony wall to avoid that ledge you end up with. i will have a 6''wide x 6''deep gutter down the centre [lenghtwise], pcv pipe in the slab to run my wiring through, i will also run a future airline from one side to the other. i plan on haveing a 2 post lift wich requires 6'' of concrete so i plan on 6'' through the entire pad. in floor heat is a must, i will also push 4'' pipe into the ground every 8' and weld a 1'' plate wich will end up flush with floor. i don't plan on a septic system but i'm going to install a future spot for a toilet just in case i change my mind. i will stop here so you guys won't fall asleep half way through. as far as the pad goes what else can i do? is there anything wrong with not haveing a pony wall? we live in northern alberta so winters can be long and harsh. thanks in advance.
