Sasquatch912
Hi,
I am getting a 30x50x12 metal building for around $9500 or so, but 30x30 will be enclosed while the 30x20 will be open. It will have one 10' roll up door and a side door.
The 30x30 will be my workshop while the 30x20 will be where I pull my 20' trailer and a project truck under. I will park my farm tractor in the shop when I am not using it or when I am not in the shop.
I am hoping the 30x30 will be big enough for what I am needing. I've never really had a shop before or a good area to work on stuff. I MAY close the 20' off later down the road and buy a separate shelter to park my trailer/tractor implements. But for now the 30x30 will be my workshop to weld, etc. I will have a 30x30 concrete pad put down.
What my shop will consist of is:
I plan to get an air compressor, plasma cutter, mig welder, drill press, bench grinder, welding table, and AC/DC welder.
I will also have a sink, plan to do some counters and a storage area for oils and stuff.
My questions are:
What's the best layout for the shop?
What's the best way to wire this? I guess I will need several 220V plugs and several 120v plugs. What amp breakers should I use?
Any opinions and suggestions?
Thanks
My questions are:
Thanks
