dmeadow
I've done some searching on this forum, so I think my plan will work, but a lot of the information applies to slightly different scenarios.
Dimensions are as above. This is essentially a double-deep 3 car garage. I've only got two windows on one side, each 2'x4'. The garage is fully finished and will be painted a light color, including a light grey epoxy floor.
I also have a 6' garage door on the back that has some windows. The front garage doors will not have windows.
My plan is to install eight 8' T8 flush-mounted lighting strips. Each one has 4 bulbs (this is the $40 light strip that HD sells).
I intend to install them parallel to the garage doors (perpendicular to the cars) evenly spaced front to back, with a bit of a bias towards the back to avoid having lights directly above the garage doors when they are opened. Some posts say that parallel to the cars is better, but I couldn't find one that explains the logic or why it makes much of a difference.
I'll also have a couple of 4' shop lights that will hang directly over workbenches located on the back of the garage.
This garage will be used for car maintenance and restoration as a hobby.
Thoughts?
Thoughts?
