Baja_XJ
Hey everyone, curious if someone can help me out on some meter base/socket & disconnect info.
I’m wanting to run a 320/400 meter, then branch two 200 disconnects off that. One disconnect would go thru the wall into the breaker panel for the garage, the other disconnect would go underground to my house 150’ away.
I’m trying to not have to spend $3k+ on a combo unit that has the meter and disconnects together that has to come from a speciality store.
I am a duke energy customer so the meter has to be MEG certified, the Eaton meter that I was looking to buy, turns out is not MEG cert so I can’t use it.
Curious what has been done by some of you others that worked out in a situation like this, or what your recommended products/solution would be.
Pic for reference as too what I’m trying to do so that it would be a $1,500 job with components from standard big box hardware stores instead of a $3k+ combo unit from a specialty store.
