32x32x10 Build log and help column
Greg5OH
This is my shop for general personal car repair, and vehicle restorations. Will be building a rotisserie later this year. Still positioning the 7k lb rotary asymetrical lift.
I will have a ton of questions along the way.
I have yet to add/position my floor drill press and 20 ton press. Not pictured is the still yet to assemble 10' wide by 10' gantry crane with two come along hoists on it. this I think will pretty much replace my engine crane.
I am hoping I can still get my 24 foot long crewcab long box f350 in the shop with the way the lift is positioned-which I think maximises space. I got 11 feet from the front arm pin to the wall. Rotary calls for 10.
All the **** on the left there is garbage and will be dissapearing.
Any comments or suggestions I am all ears.
tore out the room the PO had made
the truck that has to still fit in even with a car on a rotisserie. Due to my celing height I cant get a car raised and above the bed unfortunately. However I do have plans to go with a new truss design that will be built along side the old truss, anhored to the post, then the old truss will get taken down. It will net me a 12' ceiling along the middle 25 feet or so. Raised truss i think its called?
cleaning up from a winters worth of work on the truck
how it sits as of yesterday
60 gallon air compressor is behind the man door far left front and out of sight.
I am looking for aorudn 16 t8 light fixtures as its too dark in there still. Insulation wont come for at least 3-4 years so not stressing about that for now. in the winter time i will put in a wood burnign stove for some nice radiant heat.
G
Greg5OH
I just found out about those 30W LED flood lights. Maybe If i got a bunch of those the light output woudl be satisfactory and ill pull much less power?
G
Greg5OH
hoist is setup minus hooking up the electrical
Any input on the LED floodlights?\
G
Greg5OH
got the race car and my truck fit in there no problem. Heck i could probably put my 3rd car under the mustang if i was really compelled.
Changing hanger bearing on the truck and oil change. Easy room all around it.
G
Greg5OH
ordered a trans jack for general purchase lowered of items from hoisted vehicles
G
Greg5OH
Been a while fogured id update. The shop has come long way but hs a long way to go still yet. Always working to find a more efficient layout, for storage and workflow,
And just picked up this low rise drive over jack to put in the oversized 2.5 car attached garage, for $200! Will compliment the $300 coats 9024e tire machine nicely :D
The main garage, well im trying to figure how to make that efficient as well.
Ran a seperate 220 line, has its own compressor, but it needs to all work as a tire shop, wood shop, storage for 2 full size sedans, and garden stuff while i figure a shed out.
PEnX1oP
PNH5HQ2
