I have been wanting to do this for a long time, I have saved some parts for this project for a while, and I have been cleaning up so its other get rid of it all or finish it once and for all...
HERE IS WHAT I HAVE..
2- Brand Spanking New Ingersoll Rand 2475 T30 pumps, Wrapped in plastic, never even had the pulleys mounted or oil put in them!!!!
2-Brand new Eaton 5hp starters, I bought these a while back for a good price at a local parking lot sale, for this project specifically, I wanted to find a duplex controller for this system, but never stumbled across one, I do have one that says "230v 3hp single phase" that came off of a duplex 7.5hp 3 phase system, but I was told it wouldnt work, so that is in the "sell" pile, if anyone is interested, its in nice shape, would be good for a dual 3hp setup, a pair of 60ga 3hp units for $300 each wired to this unit would give you 25 cfm for cheap...
2- used sheaves and bushings, for a 184t frame motor, will give me around 920 rpm at 1725.
2- air dryers, 1 25cfm and 1 15cfm, both never used, scratches here and there, but never used...
AND the REASON I started this project, a 120 gallon Heavy Duty horizontal Ingersoll Rand receiver, it was only like 5 years old when I got it, but now its about 13 years old, but in nice shape... This tank weighs about 500#'s, its the one with the frame built around it, has 3/8" plate welded to it, lol... SUPER HEAVY DUTY... I used it for a long time for storage, but now there is no air running to it, I am going to move it to the home garage this week sometime....
SO, I need a few little things, like air cleaners for the intakes, pressure switches, check valves, psi relief valves, and I will fab all the copper tubing up myself...
SO I need some advice...
1st, which pressure switches? And how would you wire this? I was thinking get adjustable switches and set one to come on at 120 and off at 150, then the other pump on at 100 and off at 150...
Is there a box I can buy that will alternate the pumps using my eaton mag starters? Or a better way to do this I dont know about... Something like the dayton 051 like I would use on condensate drains in a commercial building?
2nd, Which motors, I was looking at the weg 1.25 sevrice 184t 5hp, it looks strong at 109lbs, but the baldor l1430t is the normal go to for me...
3rd, will this work properly with 2 air dryers? I was going to tee them in together, and when I know I am using more than 25 cfm I turn on the large one, when I am going to be using more cfm I kick the other one on too, I figure a ball valve on each to isolate them will work well enough....
4th, Is there a good way to find a diagram on how to run the pipes for this? I can figure out how to run it all but not positive where all the reliefs should be?
I think that is all my questions for now, I will post some pictures when I bring the tank home, I am on the fence of sand blasting it and coating it or just cleaning it up, I guess I will power wash it and then make a decision...
thanks in advance, I know there are a couple pro members here that work on pumps all day, and I know a lot of you boys have built more compressors than me, so if you can offer some help, I would appreciate it...
this is what I am shooting for, but with out the big control box, I got a price on that and you WOULD NOT want to know what it was, lol..
http://www.amazon.com/dp/B0040C01Y4/?tag=atomicindus08-20
I would love to add a second one into the system. Best of luck looking forward to this I can't wait for some pictures
