35x27 Recessed LED Panel Layout: Prioritize even spacing or task lighting?
spartansix
CT
About to start ordering fixtures and doing the rough-in for the lighting on my 35x27 3-bay garage.
The ceilings are only 9', so I'm trying to maximize usable height and aesthetics with 1'x4' LED panels in recessed drywall mounts. Each fixture is ~4400 lumens and I'm trying for ~90 foot candles.
My original layout is the first floor plan below, but I saw two issues:
1. I can't recess lights in the left-right direction because of the floor joists
2. Some of the lights are awfully close to the walls
So I put the space into visual interior and overlaid their suggestion on my plan. Obviously some of these lights would need to move because of walls etc. but is this a better approach? I don't like that the garage doors would block many of the lights when open and that the lights are over the cars rather than over the space between them.
What do you light gurus think? Should I focus on lighting the space evenly, or on lighting the areas where I am going to be working?
Noltz
Ontario, Canada
Are you working on the cars a lot? Because if you are, I'd put the lights between the vehicles and not at all over top of them. Over top creates shadows, which is in some cases worse than less light in the right places.
If this were mine I'd use the first plan, but since I'm wiring it I'd have a little fun and put it into 3 zones. Yellow comes on with the door switch. Blue and Green are used if you're working in there. Consider where you'll be entering the garage, or use a 3-way for the yellow zone with a second switch near the other door.
[/url]
StephPop24
[/url]
I agree with you, it also depends on the size of the LED pot lights...
