36" Wright Tool adjustable wrench.
Nortonscustom
Thought you guys might get a kick out of this thing. One of our mech's ordered it. No one knows why, but I'm guessing someone got a part number wrong because it's being sent back. Is a beast for sure, made all out of plate steel.
zkling
They did.
The hole in the end of the handle is for a shackle. Attach to overhead crane and haul away.
:scared: Seriously? What was the intended application? I searched that part number and it appears they make it in a traditional thumb screw design as well. Even wright calls it a giant wrench. :lol:
A_Pmech
IL
Back before hydraulic wrenches. Note the pad eye near the open end for balancing the wrench:
Cranes are also a leading cause of broken 60" pipe wrenches.
:lol:
Steevo
43.49600, -112.04300
So, for the **** types here that are compelled to close their adjustable wrenches before putting them away, how big of a pain in the *** would this wrench be?
tbaggz
Got a link to a thumbwheel version? I don't recall seeing one and can't find it.as far as I know the banco/blue point 30" is the biggest thumbwheel available. Thanks.
diggerrick
They did.
Good lord, I wouldn't want to be in the same shop as that setup. What if it came off the side of the fastener? That thing would do some damage!:shocking:
madison069
Monroeville, PA
:lol:
Laugh but at work we use the crane to torque up connections up to 1200 ft lbs with a 72" pipe wench and a torque gauge between the wrench and crane. We got hydraulic breakout and torque machines to do higher torque connections.
pilotman81
Somewhere on the road
Not to criticize, but why would you use a pipe wrench and the crane to torque things if you have a hydraulic setup? Sounds kind of dumb from a safety standpoint.:headscrat
getahammer
Central Ohio
Now I can round off the corners on even bigger bolts. Hopefully they make 48" vice grips.
Southernbuild
North MS
With that pinned head design, I don't see why there would be any play in the jaws. Thus, it shouldn't be anymore likely to round off a bolt, than a dedicated size open end wrench.
