36x18" concrete slab
P
PoorOwner
CA
I have that plastic pad, I am trying to replace it. I don't know, I just couldn't get it to sit nice on the soil, plus the condenser is still tippy on it.
benjamintmiller
IA
No, you do not need rebar or mesh for a pad as small as that.
And yes, that type of gravel is perfect under concrete. You don't need the gravel either if you don't want it.
bad_idea
Pasquotank, NC
Minimal load for a foot print that size. Scrape the vegetation off the soil, nail some 2x4s together as a form, and pour some quikrete in there.
MushCreek
Upstate South Carolina
Mini-splits are very light, so you don't need much. I mounted mine to the wall, about three feet off the ground to keep them out of the leaves and snow. It turned out to be a good idea, as the service ports are down near the bottom. You'd have to lay on the ground to work on them.
ConCretin
Central Maine
What has become of the GJ?!? Of course you need rebar and lots of it. I'd say at least #8's at 6" centers........... Just kidding. The previous posters have it about right.
kbs2244
I think most of the pre-cast concrete ones hove some kind of steel in them.
chaosracing
Kutztown, Pa
Not really. Depends on the mix used. Some just use wire fabric, others use fiber mesh, other use nothing, but I have not seen any pads with rebar in them.
As mentioned above though, if you can, I would mount to the building and raise it off the ground. Much better all around.
ItsNemo
Canada
Honestly a couple 2x2' patio stones on some gravel would be plenty for a mini-split.
renloy
Don't forget the vapor barrier and insulation too. Don't want that minisplit to get cold!
NUTTSGT
Northern Central Ohio
I like overkill personally. I'd probably use some rebar to hold the slab together if it cracks.
You mention the current pad is tippy, I think it will do the same thing if it cracks/breaks.
Personally, I'd scrape the topsoil off, add stone (local quarry close) form with 2x4s and add a few pieces of rebar. A 10' stick of 1/2" (#4) will give you two 30" pieces and four 12-15" pieces to tie together. It'll cost you about $5 or buy a 20' and keep the extra around for future use. . . .like tent/E-Z up stakes.
Overkill, yeah but it's not a sidewalk, you're actually placing a piece of equipment on it.
BTW, a pad 3.5" thick, 18"x36" will call for three 80lb bags of Quikrete.
PWC Repair
Arkansas
But what about the footer? I'd say 4" thick and 12" deep should do. Might even french drain the uphill side with perforated 1" pvc and pea gravel.
And don't forget the vapor barrier before you pour!:thumbup:
timewarp
Silverdale, WA
If you already have the pad and realy want to mess around with concrete, get a bag of quickcrete mix it and place it on the ground spread out the size of the pad, then push the pad down on it, just use the quickcrete like grout to make the ground level under the pad.
P
PoorOwner
CA
probably will try this first. And fill some of the squares under the plastic with concrete too, with 80 lb added it should help
