z28tt
I've got the opportunity to build my dream garage - a 36 x 40, so my wife can have a mudroom, of course! We're planning on building it to have a bonus room / bath / bedroom above it, and high ceilings in at least one bay for a 2 post lift.
While it's still in design, changes are way easier. What do I need to have? It'll be a combo garage / woodworking and metal shop. I'm struggling to figure out how to have a clean layout, but still have everything usable (current 2 garage is a disaster, just not enough room, and as I get more tools & materials,
Our designer broke up my 40x40 box into sections so it'd match the house (we're on a 1/2 acre lot in the 'burbs, so no room for a massive out building, and it needs to match for future resale), but that added a bunch of corners.
I'm in Zone 5 (New England), I was considering radiant floor heating with an air:water heat pump. Giving it some more thought, mini splits would give me air conditioning in the summer, as well as winter heat for similar cost. Our existing Cape (built in the 60's) is all-electric, and I plan on adding solar down the road. I'll insulate it like a house since the garage/bonus room/bedroom will be more or less heated.
3 bays, with 9' x 8' doors. I could put a half-wall in front of the daily driver cars to separate the workshop area.
For the 2 post lift, using the left bay with a cathedral ceiling gets me 13'6" over the middle. How much room should I have between the lift column and the wall for comfortable work? I've got 31" below and but could move it over for 36", but it'll pinch into the middle bay when a car is parked. I'm sure we can engineer the support column for the beam to be elsewhere, or go with a larger truss to eliminate it.
I was thinking of having a wash bay inside, but I'm an aspirational waxer. I barely find time to detail the cars now, so it's probably pointless. Not sure if I should try to add a slop sink somewhere (to strip off dirty mtb gear) - bath would be next to the stairs on the 2nd floor, and I could stub out plumbing supply and drains in case the next owner wants to turn this glorious garage into something silly, like a first floor master bedroom and bath. I could probably put in a drain (to daylight), if that's something that really would be good for the future.
The metalworking area is in left back corner (bridgeport, lathe, TIG, chop saw), and woodworking is on the right side. Not sure what the work area should be. I love the F1/NASCAR style race shops, but they don't have anything outside, and everything is in a cabinet. Seems like that's more of an assembly area than a work shop.
Thoughts on this layout (made it in sketchup)? I could go wider / deeper if it's needed, but need to draw the line somewhere. All ears, since this is probably the only chance I'll get.
