36x52 Workshop
fire1130man
Started a new workshop a few months back. Have been taking is slowly so I can pay for it as I go. Have made decent progress so far.
Front of shop will have a lift in it. Rear will be a/c and heat work shop. Would appreciate any insight and constructive criticism. Thanks
larry_g
oregon
Love the build. One thing to consider in the above picture, build a big door to allow access to the attic from the front shop area. It is handy to back a pickup up to the door and lift stuff into the attic. It saves trying to move stuff up a stairwell.
lg
no neat sig line
F
fire1130man
Thanks Larry. I had planned to have a storage area up there and was planning on leaving the space open from the front after sheet rocking.
J-man67
Delaware
Very nice! This place is going to force me to bulldoze the detached and build larger!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
F
fire1130man
Working on the Brick now. Going to put cement board the rest of the way up on the sides.
mikeniese
Looks Great!!! Lookin at exact same setup maybe 40'x56' thou. Post more pics when further along. Did you put in floor heat?
F
fire1130man
Thanks guys. I didn't do floor heat because I live in Georgia. Not much need for heat down here. Good insulation and natural gas furnace is all I need. I am going to put standard insulation in. Spray foam is a little out of the budget to do all at one time. I can work on batts a little at a time. I will post a few progress pics as soon as I get to a desktop. Thanks again.
F
fire1130man
I also decided to put the roll up doors in myself. I picked them up from the manufacturer which saved me about $250 in shipping. Janus intl is about an hour away from the house. They are the 2500 series roll ups for anyone interested. They were relatively easy to install. Especially the second one after I learned from my mistakes on the first one. I used a "block and tackle" system with a chain over my trusses to do the lifting. It worked better than expected after adding a few pearlings in to assist in stabilization.
I had them add the sheet of insulation on the back of the doors. I am not sure of the effectiveness of it, but is about my only option with roll ups. Plus, when you add the insulation sheet it automatically comes with the seals around the door. It will probably be an r value of around 4-6 I imagine. Just enough to help a little. Like I mentioned earlier, georgia doesn't get no where near as cold as I see on some of these other builds.
The two lights in the pics are just temporary while working around. I will eventually transplant those to be permanent. They are t8 high bay six bulb lithonia lighting fixtures from Home Depot. I am happy with the amount of Light they put out, but one of the bulb sockets doesn't light up out of the box. I haven't bothered to Investigate seeing the other 5 have plenty of light, but I will more than likely swap the fixture soon.
Progress is slow, but I didn't want to take any loans. On a poor firefighter/paramedic salary it will take awhile to attain the money. I am in no hurry though. Never planned on making this a job. Wanted to make sure it stayed fun. Plus at 29 years years old with minimal building experience, the learning curve is a little of the battle. Wish me luck.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That garage looks great and I'd kill to have one that size. Very nice indeed.
One question though.....why did you brick across the door opening at the bottom? Are you NOT going to have an apron, or are you going to pout the apron against the brick? I never seen it done like that before.
F
fire1130man
Good question Kevin. Not really sure other than I thought it would solidify everything a little more. I will have a front pad and that's why it is stopped a brick short. It may be a little while before I am able to pour it so I thought it would help with solidity.
