37 Degree Flaring Tools
Patrick Boyle
Western Montana
I'm in the middle of a project where I'm converting some oil lines over to AN. I've had bad luck with the hard line adapters that use brass ferrules, so I'm looking to do it properly by flaring. I see Summit racing has a kit for $30, which is tempting since I'll probably only ever use it once, but makes me wonder if it would even work considering the price of some of the high end kits like Mastercool.
Thoughts?
P
Patrick Boyle
Western Montana
Aren't tube nuts for use with sleeves and flares? The fuel line adapters on that page are very similar to the ones from Earl's that I've been using and don't like very much.
P
Patrick Boyle
Western Montana
Well, due to budgetary constraints I went with the Summit tool. I'm hoping that since it's aluminum tubing, I shouldn't have much trouble making the flare, and it should seal up good one torqued down. Wish me luck!
P
Patrick Boyle
Western Montana
Well, it arrived and I made a few flares with it. It DOES work just fine, but it IS a PITA to use. A bench vise makes life easier though. You've also got to make sure you have plenty of pipe to work with (har har). On a couple of my flares, there wasn't enough room to slide the tube nut far enough back to clear the cone attachment's arms, so I had to improvise with a big C clamp. Messy, but it worked.
Overall I don't see a reason not to go for it if you really can't pony up the cash for a nicer unit, and you're making flares on long, straight lengths of tube.
