3D printer anyone?
HoosierBuddy
Southern Indiana
I've been toying with the idea of buying a 3d printer for 3 or 4 years. In the meantime, the price keeps inching down and the capabilities keep going up and I STILL couldn't think of a single thing I NEEDED a 3d printer to accomplish.
Then I saw this:
And for whatever reason, I think that's really cool.
So...does anyone have any experience with these? Any kind you'd recommend? Anything a perspective (or is that prospective?) buyer should know?
Thanks in advance!
Phil
p.s. Here's the link to the Road and Track article on the EJ20 shown above:
http://www.roadandtrack.com/car-culture/news/a30018/subaru-ej20-3d-printed/
zendriver
Indiana
Thanks for opening this thread, I am interested also, looking to make little plastic insulators. Wondering what type of plastic these 3-D printers use in this durability
Burgerkong
Markham, Ontario, Canada
I have a printer on loan to me for the next few months, and yes, that EJ20 is on the top of my list. Right now, I'm in the middle of printing out a Voltron model and an anatomic Lego minifigure.
Loads of fun, but at the same time it takes a while and draws a bit of electricity and produces heat (in part due to the heated bed and the ghetto cardboard enclosure on mine).
Oh and be ready to waste a bit of filament getting used to the printer's settings. I primarily use ABS since it's cheaper but produces that plastic 'smell', so ventilation is probably a good idea.
Also, this is pretty much a CAD training tool, Thingiverse and MyMiniFactory only has so many models, same with GrabCAD. I ended up having to draw the Lego minifigure in SolidWorks and spent a bunch of time ensuring the dimensions were correct.
jallyn
Fort Wayne, Indiana
3D printed objects using ABS or PLA plastic are not very strong so there are limited applications for it, but it is still cool. I have used a handful of 3D printers including the well known MakerBot Replicator 2 and the SeeMeCNC Rostock Max V2 Delta 3D printer. They are fine printers but cheaper ones can be found.
If I were to buy one I would budget about $400 to $500 and get one with good reviews off Amazon or eBay.
H
HoosierBuddy
Southern Indiana
Thanks for the information guys...
Just as a point of reference on new school vs old school or, more technically, subtractive vs additive processes:
I'm currently building one of the PM model steam engines, which I plan to run on air.
Casting Kit = $150
Specialized Tools (model size pipe taps and dies, numbered drill bits, and various other tools that are likely only useful to build model engine kits) = $160
Misc. = $50
Total about $360 for the project
I have about $5000 in my milling machine and lathe that will be required as well.
So....using $500 worth of equipment and maybe $50 worth of PLA and fasteners to build the EJ20 engine would be much less expensive.
Now the steam engine will actually run off steam and the EJ20 is just a model...but let's be realistic. What useful work could the steam engine actually accomplish? In reality, they are both just models that demonstrate fabrication skills.
On the solidworks issue, I have 2 kids at Purdue (ME's) that both do solidworks. I'm thinking I could farm that part out.
Phil
Burgerkong
You didn't factor in time as well, the printing process is much, much more lengthy compared to traditional machining. That engine took him a very long time just to print, and even after printing it's not a completed part - post processing is pretty much required for all 3D prints.
I'm using a Lulzbot Taz5, but my recommendation is to get something with an enclosed (and possibly heated ala Stratasys) build chamber.
And I'm pretty sure it's not just a mere $50 in PLA as well, that's at least a spool just for the block, then a spool for the heads and another three (if you're doing colours) for the headers and valve covers. Plus the machine of course, going back to time - the smaller the machine, the smaller the build plate = more prints needed. On the other hand, the XY needs to move less distance, catch 22.
It's not just a clearcut answer I'm afraid, but additive machining is a hell of a lot easier to learn and approach though, you're up and running in a fraction of a time. Oh, and no coolant required either!
H
HoosierBuddy
Southern Indiana
If you do the ej20 build, please keep us informed. Question 1 is how big of a 3d printer is required. Question 2 might be how many hours. BTW...there's nothing easy about this steam kit either...and if you screw up one of the castings, it's $$$ to buy a replacement. So, screwups are time consuming either way, but at least you can just print another part with the 3d printer. You don't have to pay $$$ + Shipping + Handling then hope you don't screw up the next one.
Phil
