dwall174
I have a 3HP Puma air compressor model# PK 6060V
The motor draws 15 amps @ 230V & the owners manual states to allow an extra 10% power capacity for start up conditions.
I currently have the compressor connected to an old 3-wire 30 amp outlet, But I'm in the process of putting in a 60 amp 4-wire sub panel!
Given the motor's current draw, Would this compressor run ok on a dedicated 20 amp circuit?
Also what's the correct way to wire the 230V motor with a 4-wire feed?
I'm going to be running EMT conduit, So would I just leave out the white neutral wire?
Doug
Doug
