3M ThreeBond Vs. Hondabond HT
Mr_B
Reading
The pictured products no.
1184 is a rubber based product used mainly for 2 stroke casing joint sealing.
The Hondabond pictured is non acid silicone which basically 1215 1207 but the Honda one possibly black (1207B) .
Honda did have a 1184 version but no idea if currently do ...
W
Wamsutta
Amarillo, Texas
The Hondabond pictured is non acid silicone which basically 1215 but the Honda one possibly black .
In typical 3M fashion, they will take a product under one name and then split it off into various variations just to confuse people.
W
Wamsutta
Amarillo, Texas
Hondabond 4 is the same as 1184 (and yamabond 4)
If you have mostly flat mating surfaces and no gasket it's what I would use.
The service manual specifically states to use Hondabond HT (P/N 08718-0004) so I guess that's what I should get. I wasn't sure if maybe 3M was the manufacturer for Hondabond.
N_Jay
Example?
In this case it seems that even if the Hinda and Yamaha products are produced by 3M, they are OEM versions.
W
Wamsutta
Amarillo, Texas
Example?
If I punch in "threebond" into Amazon's search box, I'll get 1184, 1211, 1212, 1215, 1217F, 1217H, 1521, and on and on and on. . .
N_Jay
(Learned something new;)Threebond is not part of 3M.)
That aside:
1) Threebond make a lot of different industrial sealants and adhesives. Do you believe these are the same?
2) Amazon will show you everything "related" and often things not related.
W
Wamsutta
Amarillo, Texas
That aside:
2) Amazon will show you everything "related" and often things not related..
Threebond is not even a 3M product? Gee. . . I'm way out in left field then. 😵‍💫
W
Wamsutta
Amarillo, Texas
Three bond is the manufacturer for hondabond and yamabond
Which Three bond is this guy using in the video? He swears by Three bond but doesn't say which one he uses.
All I know by watching him is that it's very stringy and stretchy.
CGarage
United States/Switzerland
Call the OEM Manufacturer and ask to talk to an engineer for technical advice before you purchase.
The world of adhesives and sealants is complex, and you need to make sure what you buy works for the actual application.
Talk to the manufacturer before purchasing.
vwpieces
Hills, PA
After 15 years, my darn near full tube of 1184 went unusable. Nothing available local, I found Motoseal at a local auto parts.
Available, reasonably priced and fuel resistant.
3 MC cases and a few more non MC case related uses. Pretty thin easy to get tip unclogged and still usable 2.5yrs later. I like it.
N_Jay
Also, don't expect them to tell you which sealant is "Exactly the same as" an OEM sealant, or even if one is "exactly the same"
OEM products are often different (even if just slightly) than anything the company sells under its own label, and are usually proprietary to company produced for.
W
Wamsutta
Amarillo, Texas
1 hour 3 minutes in.
That looks like normal RTV right there. I find the product doesn't last very long once the tube is opened up. After about a week, it's done. I've never been able to use an entire tube on something at one time. There seems to be some debate online about whether or not to touch the sealant with your finger.
Mr_B
Reading
Hondabond HT easy get.
Permatex supra grey would probably do and does up to 500F
Threebond 1215 or 1207B be usable options rtv silicone .
1184 is what honda yamaha etc class as crankcase sealant in 2 stroke engine assembly and is a semi drying visco-elastomer (not silicone) .
I use 1184 in most 2 stroke crankcase assembly as been 100% result sealing and lasting but not nicest to apply,
dnschmidt
Phoenix, AZ
What does Threebond have to do with 3M? Nothing I can think of. One is Japanese and the other Global but basically American. As far as I know there is no connection between the two.
whateg01
doo dah, kansas, usa
If I'm the OEM and somebody calls and asks what I can use, the easy answer is use what the manual says to use, that's why we put it in the manual.
I don't understand why op is trying to find an alternative but the same stuff.
N_Jay
Not everyone wants to buy Porsche/BMW/Honda/Mercedes/GM/ . . . stuff.
There are lots of good automotive chemicals, often by the same manufacturers as OEM, and often close to the same product.
Along those lines, anyone have recommendations for the "best" Porsche/VW/Motorcycle air-cooled, split case, 4 stroke, engine sealant?
Steve_P
The OEs are always going to tell you to use their brand product because they want you to buy it from them at typically crazy prices, and there are too many other sealants for them to recommend an equivalent- that's an entire years-long project by itself. You're supposed to use Toyota coolant, RTV, brake fluid....
I've used just plain Permatex RTV on vertical transmission housing joints that don't have a gasket with zero issues.
For two cycle engines, to seal the engine casting halves at the crankshaft split, we used a Loctite product (edit: #515) in the small engine shops I worked at. It was thicker than the Loctite thread sealer but thinner than RTV. Never had a failure with it, and I think I still have a small tube of it.
jar944
Northern VA
1184 lasts longer than a week.
The vid was just to show the consistency, I never smear with a finger.
no704
Alwas used permitex avation sealant.
N_Jay
That seems to be the old standard that always seems to leak.
Last time I built one, people were starting to take about eh Yamaha sealer of the day (early 1990's)
I am guessing improvements have been made.
a "Factory" oil pan I bought for a 2000 Audi came with a tube of RTV like gasket maker (Forget the brand).
Worked great.
Machined surfaces in MB and Porsche (and I would guess a lot of the German cars) use no sealant. Just a rubberband like gasket that sits (on edge) in a groove in one of the surfaces.
Will probably be building a 914 (VW Type 4) engine in the next year or two and would love to have one NOT leak!
N_Jay
I still have a bottle of that and I haven't rebuilt a vw since the late 90s
Knowing the way Aviation certs work, it will probably be the required sealant for the next 50 years.
L.Cheapo
Manny moons ago I used Curil T2 for the case halves on my ACVWs.
jar944
Northern VA
We always use our fingers! We lay the gasket on the cardboard it came in and dab it onto the gasket lightly, flip over and repeat. Then lay onto the engine case.
I don't ever use it with a gasket. Just a nice continuous bead straight out of the nozzle on the bare case.
N_Jay
Gasket sealant, or form-a-gasket?
Two different things.
