racingtadpole
Bit of background:
Got a really good deal on a really old and sturdy 2MT drill press a couple of months ago. Only issue is that its 3phase and my house only has single phase supply. No problem, I go get a VFD and use that to make it run. Dragged it out of storage on the weekend and decided to have a crack at making it work.
So having looked at the VFD and the motor on the drill, I have a problem. The motor is wired in Delta configuration, VFD needs the windings in Star configuration. The motor can't be changed from Delta to Star without sending it to a rewinding company to have the far end of the windings fished out.
As I see it this leaves me with three options.
1 Send the original motor to the rewinders and have the windings reconfigured. This will allow me to maintain the original pulley and use both the pulleys and VFD to control the speed.
2 Buy a cheap three phase motor off evilbay that already has the windings that can be configured to run in Star and use a fixed pulley around the mid range of the original speed settings. Use the VFD only to control the speed.
3 Buy a single phase motor with a larger shaft than the current 3 phase motor and bore the pulley to suit the larger shaft size and use it like nature intended.
Options 2 and 3 cost roughly the same, option 1 is more expensive.
Im leaning toward option 2 because the VFD gives me more control over the speed than six different pulley settings will, and I already have the VFD.
What say the learned folks of Garage Journal?
