In the next couple months I will be adding a 3rd garage to our existing two car garage. It will be 18' by 36'. Kind of a odd size, but I can't go any wider due to needing to stay 12' off my property line and my existing house is 36' wide. I got many of my questions answered from this thread and others. http://www.garagejournal.com/forum/showthread.php?t=231200&showall=1 I plan on coming out of my existing 200amp panel with ser cable http://www.mayerelectric.com/itemDetailFilterPH.action?codeId=1064098 using a 90amp breaker. I think I can come out of my existing panel over the top of one finished room then into an unfinished storage room. That is my main question. There are water lines & NG line following this path secured to the bottom of the floor joist. Can I do the same with the Ser cable? Keeping a little distance from the other lines. Or should I jump up once I get throught the finished room and bore holes in the joist? Once I get to the wall I hope to jog over and go through the end wall in a hole I hope to bore from the new garage into the unfinished storage room. If I can't do that can I just run the ser cable straight through the end wall into the new garage and then jog over and into the new wall then into my subpanel? If I do that I would like to protect the ser cable some way. Maybe by putting it into conduit. It won't buried, just something to protect it for the 3'-4' it runs along my existing wall before it enters the new wall where my subpanel will be. Attached are some pictures of my existing subpanel and the finished room and the storage room.
Thanks for your help
Bob
Bob
