4 1/2 inch DRIVE impact sockets?
atikovi
Suburban Washington DC
Came across a company that sells them in sizes over 12 inches!: http://www.imperial-newton.com/impact+sockets.htm/inch/black-steel/450/6-point/standard/
What equipment or structure could possibly take 12" nuts or bolts? What does a 12" socket weigh or cost? As well as the nut and bolt? What equipment is used with this size socket? I've got a 4' long 1 inch drive flex handle for 2 inch sockets and by extrapolation, you would need a 24 foot long socket wrench for that 12 inch socket. What is the torque spec for a 12" fastener?
90zcar
I have no idea.....bridges??
Who knows but I would never want to work with it!! I hope I never even have to deal with 3/4"!!!!!
Sent from my iPhone 5s using Tapatalk
Murphy4570
West Deptford NJ
Heavy industry. Refineries, chemical plants, shipbuilding, bridges and skyscrapers etc. when you get above 1 1/2-2" diameter socket sizes, wrenches and ratchets aren't really used. Hydraulic torquing tools are used. This tooling costs $100,000+ depending on what you need. Check out a company called Bolt-Spec at www.bolt-spec.com They specialize in torquing critical fasteners.
Caman
MN
Big structures require big bolts
geojag
Little Rock, AR
That picture shows 5 or maybe 6 inch socket nuts. I want to see what takes a 12 incher.
You must have tiny hands if you think that is 5 or 6". That nut is about 12".
My guess would be ship building. There are huge bolts on oil rigs. Some structures prob have bolts that big too.
JRC3
Southwestern OH
Cargo ships are huge.
Caman
MN
I measured my hand in that pose and it's about 5 inches across. Bolt can't be more than 6" wide unless that guy is Andre the Giant.
The bolt may be only 6 inches, but the nut is probably closer to 9 or 10 inches.
wyo george
Wyoming, USA
That's some ig stuff. The largest we use is a 4-3/4" socket with 1-1/2" drive, but we use it several times a week. Oilfield stuff gets big, but not as big as ocean vessels!
metaldad
nw indiana
biggest drive i found, proto, snap on is 2 1/2 drive, 8'' socket
armstrong, martin, only go up to 1 1/2'' drive
matco - 1''
JRC3
Southwestern OH
I just noticed that the crankshaft in that picture is suspended from ropes! They must be pretty strong!!!!!
They don't want to damage the journals.
I noticed it says Baumann on the front of that truck. I am sure there are more than one of them on earth, but I still couldn't help but wonder if that truck has any relation to the Baumann from PB Swiss tools (which used to be called PB Baumann)?
I didn't even notice the name on the truck, I just assumed it was Wartsila since that's what I Googled.
rbjscott
Baytown, Texas
I worked for a large refinery. They had at least two 4 1/2 drive impact wrenches. We used a crane to suspend them, Pipe handles to keep them from turning. They weighed about 400 pounds. 2 and 2 1/2 inch impacts were more common. Later they went to hydraulic tightening for safety reasons.
Petey156
I'm curious what would drive these sockets. Think of the weight of the breaker bar
