4/12 truss storage???
67fastback
Pelham, Ontario
Hello.
New to the site. Planning on building my detached garage this summer. It will be a 28x40 with 12 ft walls. I was planning on using standard fink trusses, but I was thinking I could add some storage space in the attic. The only issue is it has to be a 4/12 pitch to stay under the height requirement. Has anyone used a different truss design to add some storage? I realize it will only be about 4.5 ft tall, but it’s only for seasonal light storage.
Any info would be appreciated.
mike93lx
Richmond, VA
my house has fink trusses and is around 6/12. it's also 28' deep and there is plenty of room for storage.
I have it decked with 1/2 ply down the center of half of the attic and I can double stack bin and leave an aisle down the middle if I put the bins between the trusses.
i guess you could have an attic-style truss spec'd, but if it isn't getting finished, you really won't gain anything over a fink
also, that 4.5' will get eaten up if you build up for insulation. mine are 2x4 trusses, with an additional 2x4 parallel on the bottom cord and a 2x6 perpendicular. the plywood is laid on top of the 2x6's. i also have interior walls below, so I am not worried about the modest weight up there...another thing to keep in mind.
