4 electronics side cutters - short review
driven04
Germany
As I mentioned in the "old world' Thread, I wanted to add a bit more of a review. So I'll first post the first pictures then get into the content : link to the album directly https://imgur.com/a/ZbLc0LS
Part Numbers:
Knipex (DE) 78 91 125
Schmitz (DE) 1232EP02
Piergiacomi (I) TR5000PR
Tsunoda (Jp) PM-120 18G
I wanted to get a variety of comfort grips/dipped handles, and the two main styles of cutting heads to evaluate my own preferences. I additionally wanted to try a variety of brands because I'm looking to purchase a number of additional pliers/cutters and wanted to evaluate. I mostly cut solid copper wire of about 1.5mm diameter. I actually measured it with a caliper and it was ~1.33mm, which, while I'm not stickler for following tool specifications, does seem to fit the Piergiacomis rather low limit.
With a tool like these, there are three things that matter to me. First is the cut, and while there are literally hundreds of versions of these depending on what you're cutting, there are a couple parameters that matter, like force, and feeling ie how controlled the cut is. The second is comfort/usage, and the third is longevity. I can't really comment on the last one obviously, but I can comment a bit on quality.
I have to provide a bit of background. I live in Tuttlingen, which is a very small city in Germany, but like Solingen, it's known worldwide for being the center of German tools. They're just a very specific type of tool, those used in surgery. I am very well versed in the manufacturing and quality requirements of these tools and while the price points, requirements, and design limitations are, of course, different, at the end of the day, a quality tool is a quality tool. Samual D, perhaps these will satisfy your "clean aesthetic".
The gold plated handles indicate that the instrument has carbide inserts, but if you look closely at the tip, it's difficult to tell what is stainless and what is carbide. (sorry for the potato quality, if there is interest, I can grab a real camera and take some of the instruments I have. )
Take note of the uniform finish, the hand finished smooth surfaces, and a clearly uniform cutting edge. These are the signs of a proper tool.
I have to give top marks to the tsunoda(cheapest of the bunch I think... tough to tell when taking into consideration the shipping/tax coming into Europe.) These are nicely manufactured. I was a bit surprised by the compression pin as I didn't understand what it was there for, but it limits opening travel. Perhaps unconventional, but effective, strong, and low cost for sure.
As I mentioned in the other thread, I was really disappointed in the Schmitz. It started with the presentation of the instruments, which was packaged fine, but covered in fuzzy dust. These had obviously been oiled and left out in an environment with lots of dust. This isn't a big issue obviously, but then I started using them and taking a closer look.
The two areas I'm really disappointed in the schmitz are A) the actual craftsmanship, and B) the overall level of quality for being the most expensive in this group of relatively "Low" cost cutters.
These are rough. These look like someone took a hand file to clean up a botched milling effort. On top of the overall poor craftsmanship, the surface had several scratches and grinding marks that had not been cleaned up and finished properly before shipping. This is unacceptable for any tool manufacturer in my mind, much less a "premium" tool manufacturer. I am convinced that if a manufacturer can't get the low end of their product line correct, the likelihood of the high end being done properly is zero.
The handles were fine, but i'm not a fan of the "sticky" smooth surface and prefer the tsunodas textured dip. It's one of the reasons I didn't get a dipped knipex because they use a similar coating.
To be honest, I prefer the double leaf spring off the Schmitz, but both were functional. The schmitz cut well, but it was all or nothing, whereas the tsunoda felt a bit more controlled and effortless.
Function wise, I think they are at minimum equivalent, but only time will tell.
Onto the other "style"
I'll be honest and say I was a bit biased towards knipex coming into this as they have a great reputation, and I have some other knipex tools. I thought the little sheet metal "lead catcher" was a bit of a gimmick, but it actually works pretty well and it's not in your way as much as I thought it might be.
Overall both of these cut very similarly. The knipex are rated to 1.6 instead of 1.3mm, and the handles are both decent. I'm not sure I like the "Flair" on the piergiacomi distal end, but it's not really in the way and
In general, I have relatively large hands, but really it wasn't an issue with any of them.
I didn't like that the piergiacomi has a relief of the cutting edge, meaning you can't just press the wire into the blades and cut, you have to position the wire on the cutting portion of the blade and then cut. Not a huge issue, but still significant in the design.
The only issue on the knipex is the return force on the spring is a bit weak, but it's not an actual problem, I just like a little tension in the tool while I'm working.
Citation
Indy
Tuttlingen, I've been there to meet with Storz. The one hotel was full so I had to stay in the other about 4 km out of town.
I've got a few surgical tools myself. Very nice but for electronics, well I use Xecelite or Hakko's models which are the same oem as the Piergiacomi cutters. I like both and in lab settings assume someone will use them on something other than soft copper so lower cost is a value to me. At one of the places I worked we had to cut tungsten wire rope in mfring. It was something like 0.8mm but it went through cutters fast! I wish I could recall the brand we used.
Samuel D
Interesting review and photographs. I can understand your mild disappointment with the Schmitz better now. And yes, those surgical cutters are beautiful!
D
driven04
Germany
I have to wonder if I missed one fact that might be relevant. The Schmitz cutters are ESD compliant, which is maybe why they are the cost they are. I was actually surpised as I don't see that many dipped ESD compliant tools.
As reference, the prices ranged from the ~8 euro +/- 20 percent for tax and shipping of the Tsunodas, to the ~32 euro of the Schmitz. Knipex were 20 euro, and the piergiacomis were ~15.
I think they'd all work well for the occasional use setting, and My understanding is that from Hakko you can get the piergiacomi for 5 USD, which seems like a great option.
Personally, I think i'm going to acquire some more knipex and Tsunoda tools.
I'm also surprised at how bad the iphone is at macro images...
mr.lemons
UK
Great write up. I wondered what the adjuster on the Tsunoda was for. Makes sense for anyone cutting a lot of small gauge wire.
Edit. Not an adjuster but a fixed stopper. Thought it was a way to adjust how far the jaws opened. :eek:
D
driven04
Germany
A couple updated pictures with a camera instead of a phone. Of particular note are some better pictures of the schmitz showing what I was talking about:
mrjaw14
Nashville, TN
Btw, for those interested, Amazon sells the Hakko CHP-170 version of the Piergiacomi cutters for just over $5.
https://www.amazon.com/dp/B00FZPDG1K/?tag=atomicindus08-20
I have a pair of those. They aren't Knipex or Xcelite, but they do the job for flush cutting zip ties and small wire. I'd definitely buy them again.
I recently saw that Klein now has some electronics cutters. Here in the states they are only about $12 I think. Viewed through the packaging they looked poorly machined, or possibly that there was some junk from manufacturing that stuck to the oiled surface. I was curious if anyone had tried them.
https://www.homedepot.com/p/Klein-T...+flush+cutters}:qu+nr:{klein+flush+cutter}:nr
928'er
Wine Country, CA
I just received a pair of the Kleins along with a pair of the Tsunoda MNK-125's.
In comparison, the Klein's are unacceptably crude. The grind is very poorly done, you can see daylight between the closed cutting edges. I'd estimate that the blades only make actual contact for about 40% of their length.
By contrast, the Tsunoda's appear to be a precision instrument - no comparison. The Tsunoda's are in a different league altogether.
If I hadn't thrown away the packaging and it was worth the hassle of sending them back for $10, I'd be sending the Kleins back - they're that bad. As it is, they'll just go in the junk drawer. Spend the extra $5 on the Tsunoda's...
James
Spacey_G
Do the cutting edges on your Knipex pair line up perfectly, or is there a little bit of misalignment?
I have a pair of 78 61 125 and when they were new the edges skipped just a bit. I figured it was sloppy finishing so I ground them down so that they line up perfectly. However, I recently looked at the product page (https://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1367&groupID=1483) and noticed this:
"Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life"
Seems like that may have been a feature rather than a defect. Oops!
shteii01
Indiana, USA
If I needed some; I would have them for sure:
Notice it says up to 16 AWG...
So. Funny story. I bought 3.Peaks flush cutters (similar to Tsunoda shown in this thread, tapered head, spiral spring). On package it said: Up to 10 AWG. So. I have been using them for a couple of weeks. And finally the bug bit me and I went to cut 10 AWG stranded insulated wire for a ground strap, tried to cut it, broke one of the cutting jaws. Conclusion. When they tell you what gauge not to cut, they mean it!
928'er
Wine Country, CA
Not to belabor the point, but I thought that Klein made quality tools. However, the Klein "Precision Flush Cutter" (at least the pair I received) are poorly made ****. Zero quality control - or these would not have not left the line. Buy something else.
James
