4' led lights across ceiling how do i space them
rentonhighlands
Hello:
I have a garage that is 24' wide and 30' long. My plan is to hang 4' led lights 12 in total. My plan is to hang them in a line of 3 lights each row. I want them spaced equally across the 24' from side to side. What detentions do I need to use from wall to wall to equally space 3 lights in a row? Would it me every 8' on center of light fixture?
gnab2
Following since I have the same set up but 26x41. I was going to run row of 5
Sent from my XT1650 using Tapatalk
Is0ld0ut
Subscribed. I have a garage similar in size. I am planning on doing 3 rows each switched separately and run lights end to end all the way across. Too much?
Lithonia Lighting® 8' 8200 lm Gloss White 2-Lamp LED Multivolt Striplight at Menards https://www.menards.com/main/p-1459474229643.htm
Sent from my LG-D801 using Tapatalk
Angelfire
New Mexico and Ireland
A lot depends on what sort of lighting you want near the walls. Are you planning on detailed work at benches or 18" shelves at the walls, etc...? With only 3 rows, the easiest way would be to put one row down the center at 12' and then space the other two off the walls according to how much light you want/need near the walls. One general setup would be 3' from each wall and another row down the center at 12' as an example.
