*** 4 Post Garage LIft installer in CT
mp333
New England
Looking for some recommendation for a four post lift installer in CT. I have not decided which one to get. Looking to also get the sliding jack as well.
At the moment looking into Bendpak HD9xxx, DirectLift Propark 9 or Eagle Lift MS-XLT8000. Not sure if I need the extra length?
Thanks
Chevy-SS
Rhode Island
I was very happy with TEC based in Attleboro, MA. I believe they service Eastern CT, but you do not indicate your location in CT.
I bought Challenger 9,000lb 4-poster from them and had them install.
Good luck.
bobabuee
HAZLETON, PA
diy it easy as long as you have 3 items cherry picker engine hoist ,set lift straps 2 to 4 saw horses, takes longer with one person but 2 people it snap it took me myself and I approx.. 8 hrs to complete bendpak hd-9 stx. hard part is runways they are heavy awkward. but all can be done with one person. 2 hrs getting off my trailer and laying everthing out as it goes
together. lay columns flat on floor then slide crossbeam in columns to bottom then pick up both columns or in my case one column and other one comes up too easy as pie do same to other and your 50% complete . if more info I can supply.
buy bendpak lift it is more stout and made better than other two, no exposed cables and crappy safety bar locks to set up . and 220volt pump motor which will last longer and lift faster than 110v stuff.
lynnbilodeau
Oklahoma
My wife and I installed our 2. We only needed a cherry picker to get them off the trailer. Once on the ground, we did everything with hand tools. First one took us about 3 hours, second one 2.
HeadsUp
Central CT
Where in CT are you located. I'm in East Hampton and could lend a hand if you need one.
I did mine by myself using a engine hoist. Couldn't have done it without it.
albaran
Stratford, Ct.
If you are in the Fairfield County area, call Carlifts Plus in Norwalk. 203-509-5353.
They did a presentation to our car club and I was impressed with their company.
thickhead
Connecticut
Just to add to this old thread I found....
I used Mastercrafters out of Middletown in 2014 and they did an excellent job on my bolted down 4-post install.
Couple numbers I have for them: Ken @ (860) 635-3886 or (860)655-5438
mp333
New England
Thanks. I am all set. I did call a company out Middletown several times. Never heard from them. Not sure if it was same company.
