1956f100
Just set-up a new to me 4 post lift ( Backyard Buddy ) , but could be same issue with other brands. When raising the lift to maximum height, loaded and unloaded, the plastic reservoir tank severely deforms inward as the fluid is drawn out, and returns to normal or slightly bulges out when the lift comes down. Checked for proper oil level in system. Factory suggested air in system, and to run up and down with tank cap off to bleed. Did this numerous times. Lift operates properly with a vehicle on it. Can get tank to not deform if I crack the fill cap to draw air in on the up cycle and expel air on the down cycle. I feel I am missing something fundamental in the operation.
Any hydraulic gurus online that may be able to provide some info? Thanks
