I've read quite a few threads on the 2 post or 4 post lift pros and cons. What I haven't really read and would be most important to me is can you pull an engine from the top when using a 4 post lift. I know the front crossmember is in the way for a cherry picker, but it seems like you could raise the lift a couple inches off the ground then roll the cherry picker under it?
I'm leaning towards the 4 post because I want the ability to move the lift around my 30x40 shop and I have no idea if the concrete can hold a 2 post. I also like the ability to use it for parking or a large work bench when not in use.
If a cherry picker wouldn't work, could a mobile gantry crane work if it's wide enough and tall enough to clear the from posts?
