Zedder
Back in the fall I had a Direct lift installed in my standard 18 x 20 2 car garage. At that time, I noticed that the posts closest to the wall were not totally plum due to the fact that the garage floor is slightly sloped towards the middle of the garage (like many I suspect). Since I have 2 separate 8 foot wide doors, the lift has to be located about 2 inches from the wall. In the fall, it appeared that the posts were about 1/2 further away from the wall at the top vs the bottom of the lift. Now, it appears to be about 1 inch likely because of the ground under the slab freezing over the winter. This makes me nervous and I want to correc it, but I don't think I can anchor the posts to the slab since 2 of the bolts would be only 2 inches from the slab edge and the manufacturer says they must be at least 6 inches away.
I hope I explained that clearly! Any suggestions????
