4 Post Lift Users, Where do you store your ramps?
Dakota00
Woodbridge, Ontario
Curious to know where you guys store or place your ramps when the lift is not in use? Currently I place my ramps on the side of the lift. Looking for some ideas where to put them so they're out of the way.
Pic of where I keep the ramps.
View media item 41595
c39er
Seattle, Washington
I made my own so they would flip up out of the way. The new old hang in the way ones are down in the barn where they belong!
grommit
I store mine behind the rear wheel on the same runner that the tire sits on. Your not going to move the car anyway.
workhurts
VA
I let them hang. They're almost parallel with the runways anyway so I can lift everything up high enough so I don't knock myself out.
Ray916MN
Orono, MN
I let mine hang when the lift is in the top position since they only droop about 6". When the lift is lower I put them behind the wheels of the vehicle on the lift. I also keep my jack tray at the back of the lift, so if there isn't enough room behind the wheels for the ramps I can rest them on the jack tray between the runways.
NitroShark
Greenville, SC
I don't store mine because I originally bought the optional Bendpak ramp brackets. They worked well but did not raise the ramps to max lift. I tig welded some tabs to them and added some valve springs to hold them up to Max height. Worked out great, Shawn
Photo shows the modified lift springs added on the right and stock brackets left.
ebmiller88
I have a DL and mine sit perfectly between the ramps, on the lip of the ramp. Like they were made to go there.
