I plan to order an HD-7W in a few days, and have a few final details I'd really appreciate feedback on.
Wiring
When the garage was built, I had a 30A 220 junction box installed in the 14' ceiling above where I had planned to install a 2 post lift. Plans changed, so to make this work with the 4 post setup will require a run from the junction box to the rear and right of the garage (about 10 and 6 ft, respectively). To make this look decent, I was planning to use white painted conduit and hangers to suspend the run about 6-12" from the ceiling, then downward to the left rear post. I haven't been able to find any examples of how this would look though.
Alternatively, if I use 110, I can just plug the lift into a wall outlet (20A) about 6 ft from the left rear post. This is definitely the easiest option, but I'd rather not have a cord on the ground. Is it common for people to simply plug the lift in when needed, and unplug it when its not? The lift will be used primarily for storage.
Lifting Speed
From what I can tell, while there is a difference between lift times, many people don't seem to mind the slower lift speed of the 110. For those of you that have used both, now that you've lived with them, do you have a strong opinion one way or the other?
Bendpak's Compressed Air Bottle
I like the concept, but not the cost. For those of you that have them, how's the reliability been? Knowing what you know now, would you have made the same decision? Since I don't have a decent supply of shop air yet, I'll have to use a small compressor for now.
Wiring
Lifting Speed
