bczygan
If you have an existing 3 wire, what kind and size of wire would you run to get the 4th (Ground) wire?
I realize that in some cases it may be difficult (or costly) to run a new wire, but if the local electrical code requires a 4 wire receptacle, then I would think prudence dictates that you do it.
read it again! that applies to the cooktop, not oven!
Zero difference. Stove. Oven. Range. Semantics... The electrical requirements are what matters. I could see if it were a 120VAC cook top things would be different.
Tommy
No exposed metal? Your oven is made out of plastic?
Tommy
More semantics... The entire unit is made out of non-conductive materials?
That's what determines the electrical connection, not the surface of the "cook top".
Tommy
You would fail badly working in an appliance store. It is not semantics, it is like saying you fill up cars and big rigs with gas.
There is NO metal exposed during normal use. Only on the underside that one may touch when servicing the unit. nothing a person would touch in the course of cooking a meal is metal.
And no 120v used at all.
And the installation meets current code as the circuit was installed in 1967.
The oven was upgraded to a 4 wire when changed.
The application of common sense is more important than 'semantics'.
No!Cant i just run a seperate ground wire from stove frame to a good ground rod drove into the ground outside? Wouldnt that be the same?
Can you explain? Why would a welder need a 4-prong? Or did you install it for something else?Went thru this while installing a welder outlet in my garage. I installed a 4 prong, then changed the welder over to 4 prong. At least the house is to code and the welder doesn't know the difference.
