My AC in my house is not quite enough when the temps go over 100*. I have a 4 ton unit. The inside part is pretty old, but the outside unit is newer. A heat and air guy said since the outside was fairly new, I could replace the inside since the cabinet is starting to rust, with a 5 ton with a 4 1/2 ton orifice-that maybe the wrong term. He said it would give me the equivalent of 4 1/2 tons. Then at a later date replace the outside unit with a 5 ton when it goes bad.
Do you heat and air guys think this a good approach?
No.
You need to have a load calculation done to determine the proper size equipment.
You do not mention the indoor temperature that you are trying to maintain. For what it's worth, residential air conditioning combinations are rated at an indoor temp of 80*F. Once you go lower than that, some other stuff needs to be factored in.
Once the building load and your personal indoor temperatures are determined, then the equipment size can be determined.
Then, the ductwork needs to be evaluated to see if it is properly sized to the airflow requirements of the proposed equipment.
If you do not have ductwork capable of passing "5 tons" of air, if you really need "5 tons" of cooling, you will NEVER get "5 tons" of cooling out of the system... even though you are paying to move "5 tons" of fan and compressor.
That's the right way to do it.
The hack installer or cheap customer will just slap in a bigger unit and see what happens.
Good luck.
