If your jack leaks completely dry when just sitting idle, is generally a reservoir issue. I would first inspect the bottom of the jack, to see if there have been any rubbing issues, paying close attention to where the tank nut meets the reservoir. If there is fresh oil on the Ram or weeping on the inside of where the tank nut seals, this is a indication that the main ram seal is probably compromised and it will need to be further disassembled to evaluate the problem. Hydraulic jacks are funny creatures.. Especially these 93657's I've seen situations where the pump pistons are leaking and the oil will start there and run the entire length do the unit and make you think that they are leaking from the ram end.
