4 way dimmer switch?
jb garage
Dallas Texas
I thought I found a good thread on this previously but can't refind it.:headscrat Thought it said I could use a 3 way dimmer switch but it has to be installed at a specific switch location, perhaps the closest or first switch to the power source? Anybody?
(I have 3 light switches. )
ard
Agree
And if you want a dimmer that can be controlled from ANY of the 3 locations, it can be done with a zwave switch (or other similar remote controllable devices). Just FYI
rlitman
Long Island
Agree
Doesn't have to be wireless. Leviton Wi-Fi switches have a head unit and remote units. The wiring diagram is different, but it lets you dim from all locations.
cybrdyke
USA
casetawireless.com
Just put in one Maestro wireless switch and then put your remotes wherever you want them.
CD
ard
Yeah, thats what I meant.
There is one 'dimmer' and the others are remotes. aka 'remote controllable'
They dont need to use the Z-wave or wifi capabilities to control.
White Shadow
I just went through this in my house, I was installing a Jasco smart dimmer switch (and the accompanying Add-on switch) to control the chandelier. The master switch is downstairs by the front door and the slave switch is upstairs in the hallway. The whole time I thought I was replacing a 3-way switch. I couldn't get the smart switch to work at all. Turns out that it's actually a 4-way switch and that third switch is on the other end of the hallway. The simple solution was to flip the third switch and just not use it. So if you want to go with a smart dimmer switch, it's an option as long as you don't use the third switch. You can control the dimmer from either the master or the slave, or from an app on your phone as well.
ard
Good news is that another slave is cheap.... I couldnt sleep knowing it was wired as you describe. Even on your place! :beer:
White Shadow
What do you mean? I didn't touch the wiring of that switch. I just flipped it and now everything works as it should.
ard
Not familiar with Jasco. Many z-wave switches just need a single control line from one slave to the main dimmer. Existing 3/4 way wiring will let you add the slave controller...for example:
ge-z-wave-4-way-switch-wiring-diagram-unique-3-and-4-way-switch-wiring-diagram-27-with-additional-duct-entrancing-18q.jpg
White Shadow
My Jasco is a Z-wave. But the slave requires the load and one traveler to be connected together. So I don't know if I could simply add another slave or not. But simply flipping to he switch into the "other" position makes the master and slave Jasco switches work just fine.
