bjochman
The wife wanted me to add a third switch in the basement to turn on/off a set of lights, thought no problem, but can't seem to get this right, thought maybe someone could help out. From best I can tell power originates at first switch and also the "feed" to the lights leaves from this switch. The 14-3 wire then goes to the second switch with only the red/white/black wires at this switch, nothing else. I took this switch out (2nd switch) and put a 4 way switch here, I wire nutted the white wires to the new 14-3 (white) wire going to the new switch, then put the "pairs" of red/black from incoming/outgoing 14-3 wires on the 4 way switch. I then connected the old 3 way switch to the new 14-3 wire. Turn the circuit breaker on, the two 3 way switches work properly (no matter what position the 4 way switch is in) but the 4 way doesn't turn the lights off. If I move the 4 way switch to the "middle" the lights go off. Any ideas? Was I not suppose to wire nut the whites together? Thanks in advance for the help.
