bczygan
So there is a panel in my basement, looks like it's fed from the meter box.
Two 220V circuits in it, 40A and 30A. No main breaker. The 40 served a range sometime in the past.The 30A served a dryer sometime in the past.
I want to use the 30A circuit for a very temporary (Until I get a new main service panel) hookup for a compressor.
The 30A circuit has black and red going from the breaker to the outlet. A white and ground go from the combined neutral/ground buss bar to the outlet.
I've cut the outlet off because it is water damaged.
I want to connect a 3 wire to this circuit outside of the panel, using the existing wires. My three new wires are black, white and ground.
Do I connect new black to existing black and new white to existing red and leave the existing white capped? Grounds connected of course.
Thank you to all the sparkies!
Bill
Bill
