sdowney717
- Joined
- Mar 17, 2010
- Messages
- 964
The relay is the VF4 series SPDT standard type car relay.
Curious if they can switch an AC load?
If I used that relay, Less than 60 watts of AC power would be turned off and on
I probably will just use the current DC/AC magnetic breaker switch.
Currently I have three 12 volt DC engine room lights with edison bases. I plan to switch to using three flourescent screw in bulbs.
40 Amp Relay with PC Board or Quick Connect Terminals for Automotive Applications
40A continuous contact rating @ 85 degree C
1 Form A and 1 Form C arrangements
Plug-in or PC board terminals
Optional mounting bracket
Various enclosure options
