zombiescustoms
Day 15: roof is covered
congratulations on the new garage partner . He looks like a big boy. Great looking garage.
Going to pour the apron out to the driveway??
Looks great! How are you going to access the space up top?
Is your dog a American Bulldog ?
Zombie's Customs......What pitch is your roof that gave you a 12' x 8' room up stairs? Thanks.
There will be a regular walk up staircase in the back corner up to the middle on the man door side.
Thanks! I'll have the same pitch roof and truss system. Yours looks like it will work fine so thats what I'm going with. Now, If I can get this guy to get moving! Your posts have been a great help!
Hello Zombiescustoms, I'm having a 24 by 24 foot garage type structure erected beside my house. It has a 14/12 pitch roof and therefore a very usable 12 wide, 24 long and 8 feet high space on the second level. The building is roofed, sided and waiting for its poured concrete floor. It's looking amazing but I'm driving myself crazy on how to access the second floor from inside the building. Have been looking online at Bessler one piece pull down stairs for the past week or so but just found your Garage Journal album and thinking maybe I shouldn't give up on the idea of fixed stairs! I have 10' 3" floor to floor. Could you tell me what is the width of your stairs and dimensions of treads and risers? I'm assuming you also had trusses 24" o.c. from the looks of things, which means that you apparently cut one of the trusses to lead the stairs into the upper floor. What sort of header construction or other structural solution did you use to compensate for cutting the truss? A terrific building! Hope to hear from you so I can figure out a solution and put my mind at ease on this problem.
Sorry for the time lapse, the stairs are 36" treads and ended up about 42" overall, the truss is not cut just doubled and then one left out to make room for the staircase, no other changes were made.Hello Zombiescustoms, I'm having a 24 by 24 foot garage type structure erected beside my house. It has a 14/12 pitch roof and therefore a very usable 12 wide, 24 long and 8 feet high space on the second level. The building is roofed, sided and waiting for its poured concrete floor. It's looking amazing but I'm driving myself crazy on how to access the second floor from inside the building. Have been looking online at Bessler one piece pull down stairs for the past week or so but just found your Garage Journal album and thinking maybe I shouldn't give up on the idea of fixed stairs! I have 10' 3" floor to floor. Could you tell me what is the width of your stairs and dimensions of treads and risers? I'm assuming you also had trusses 24" o.c. from the looks of things, which means that you apparently cut one of the trusses to lead the stairs into the upper floor. What sort of header construction or other structural solution did you use to compensate for cutting the truss? A terrific building! Hope to hear from you so I can figure out a solution and put my mind at ease on this problem.
Very Nice Build!!!! I am looking at building about the same size in Ohio, except I have to brick my exterior (That should add a few grand)....
Can I ask about how much you have in it at this point of the build? I want to get it to where you are right now and then continue to finish the interior over a few years to spread the cost out.
Thanks,
Brian
