Doing my first house flip, I usually do commercial projects. I’m not sure what to do.
This is an 1800sq ft twin in an upscale neighborhood with victorian homes. I have an existing 100amp panel. I have a 60amp subpanel right next to it as well. The 100amp panel is full.
I’m installing hvac now, and the hvac guy decided to use one zone as a gas heater and one as a heat pump, both have AC. The electrical requirements for these systems are
Unit 1 -50amp breaker for heat pump strip heat
Unit 1 -20amp breaker for its normal duties of blower/ac/heatpump
Unit 2 -20amp breaker for normal duties of blower/ac
That actual heat in the heat pump strip is a 8kw, which has an actual load of 33amps (i think).
I’m trying to get away with not upgrading the main panel. Because then I have to upgrade the service feed, and it’s pretty expensive. Is this going to be ok?
My plan was use that 60amp subpanel for all the hvac. Or maybe upgrade that to an 80amp. Which is easy because it’s right next to the main panel.
Thanks in advance for taking the time to read!
Edit:stove is gas, dryer is gas, water heater is gas
