imma_stocker
Looking for recommendations, reviews, advice and discounts.
Auto shop at home. Lots of various chemicals with moderate fabrication. Virgin slab poured 60 days ago so fully cured.
Metal building 40x40 spray foamed. Attached 20x40 carport.
I've had sealed concrete, smooth epoxy, and heavily textured epoxy shops before. Not a fan of smooth epoxy due to major slip hazard. Sealed took a lot of damage and staining over time but no slipping. Textured epoxy was already damaged and I certainly didn't help.
Concerns:
Slip hazard
Durable to LOTS of chemicals
Durable to impact, scraping, wear, and temperature cycles (mostly heat)
Durable for fabrication sparks and slag
Visibility to find those rouge hardware once they hit the floor
Cost is a factor. Bunch of friends have recommended everything from leaving concrete raw to laying carpet. I'm looking for advice on specific materials for inside vs outside. Outside less important. Inside I've even considered doing epoxy half where the lift will be then just sealing the other half.
All advice greatly appreciated!
I'm in Texas. Frost and salts are not an issue.
Concerns:
Slip hazard
