Nice place. I was thinking of using a few ceiling fans as you did to help push warm air back down because of the 16 ft height. Do you think they help much with that?
thank you!
as of right now, with VERY limited time up there, i cannot say if the fans do that much good - in theory they would, but i just haven't had much of real life experience yet - it is all VERY new (since early october 2015)
i was up there very briefly this weekend; the heating system and spray foam insulation work well in tandem as expected.....it was in the 40's outside.....t-stat was set @ 56...inside temp in both the shop and the apt was 58
turned up the t-stat temp to 70..(about 7pm on friday) ...worked in the shop for several hours and ran some errands friday night and it took 4 hours to rise 4-5 degrees (which i had expected because it is not like a forced air system)
went next door to the main house to sleep.....woke up at 7am and walked next door to the shop, the apartment and shop were both at 70 and felt great
i bought a Flir E5 (thermal imaging camera) so i could monitor a few heat related things in the building (very cool gadget btw)
with the fans OFF....the ceiling was still at 70 degrees working height, at 70 as well....turned the fans on......and checked temps again a few hours later....roughly the same temps at the ceiling and working height.....i just noticed the actual cool draft of the fan which was counter productive
i will be spending more time up there the next several weekends so i can try a few things with the fans running at various speeds and also shut off
Will report additional info as it gets colder
