40x64x14 Build in Ohio
HiItsMeJimmy
Been lurking for a while so I figured I'd join the community! Build is fairly simple. The two garage filled up rather quickly so I finally pulled the trigger on something bigger to hold a couple toys. Garage will progress as I get time and money!
40x64x14 All metal pole building
3 12' Doors
200 Amp service
Water, Etc.
Radiant Floor heat
Lift
Land wasn't the greatest so it took 3 days of moving earth.
H
HiItsMeJimmy
Building squared up and marked off, trusses also dropped off.
Got the holes dug after work
H
HiItsMeJimmy
If the weather hold off monday I'm hoping to have the trusses set and rough in the plumbing!
Aaron P.
thats the same size i would liketo build :D.....one day i will :sad:...looking good so far
H
HiItsMeJimmy
Holy Spring! Came home from work to find this. About 2.5 feet of water ponded up in the trench.
H
HiItsMeJimmy
Gotta give credit to the excavator, he took care of the problem the right way!
Even got bathroom roughed in
NUTTSGT
Northern Central Ohio
A few posters have asked a couple of questions. Some common courtesy on GJ is to answer questions if you want others to follow your build.
H
HiItsMeJimmy
Garage is located in St.Clairsville, Ohio. A few amish guy put it up and a buddy is helping with the excavation.
H
HiItsMeJimmy
Amish were $3,000 cheaper to put up the building and $2800 cheaper to pour the pad. They are 104 miles away one way. I worked out a deal with them and bought home depot gift cards through giant eagle and they use the fuel perks to drive here. Well they don't but their driver does! I'm pleased with their work plus they show up and work! Hard to find these days.
Tamper84
Clarington Ohio
St.Clairsville!!! Sweet your about 30 minutes north of me!!! Sweet garage, and keep it going!!! What amish did you go with?
NUTTSGT
I thought you were going to have a ton of room if you were putting Beetles in there but that Lincoln will take up the same space as two VWs.
