'41 Poncho Shift Linkage
Winged Avenger II
Wisconsin
'41 Poncho 3 on the tree sometimes won't go into gear. If I move it through the gears and then go to the gear I want, works better. Need just a couple of bushings or what?? No trans. slippage when driving, just getting smoothly into gears. Thanx??
have2goski
o suggestions for you on your problem but....
you should try to post over on performanceyears.com forums. All pontiac guys over there. I have found good information there in the past.
